I have a third-party app, Pitikapp, that suggests using hwinfo with it and I very much would like to do so. The app Pitikapp seems to get its data from a task such as msiafterburner. If msiafterburner is not running as a task, pitikapp will not see it and then no data. I have no issues with msiafterburner. It starts minimized as a task on startup every time, no drama. Same for pitikapp, and the two apps work wonderfully together.
I cannot configure hwinfo to run as a minimized task on startup. I have tried with both the last two versions, uninstalled and reinstalled them countless times, played around with the startup options in every conceivable way, but no joy. Confusing the issue, I have gotten hwinfo to run that way a couple of times, and then pitikapp was able to get data from it. But I don't know what I did to make it work. I have also seen it appear for just a second in task manager, but then just as quickly it disappears.
Can you help?
Can you help?
