How to restore settings
schmar
Hello everyone,
I saved the "HWiNFO64.INI" and used the "store all settings" option in the main menu.
Now I copy/pasted the old HWiNFO64.INI in place where the new installed blank one was, renemed the new installed into "HWiNFO64.INI new" before and then I double clicked the settings files...
But nothing happend when I started HWinfo again.
What did I do wrong?
Thanks
Markus
Only some portable settings are stored in the INI file. The other settings which you exported are saved into a different (.reg) file that you have chosen to save. To restore those settings you need to launch the .reg file.
Launch the reg file by double clicking it? I did that... Windwos said it was fine, it was written into the registrie.
Do I need more than to start HWinfo after that? Because nothing is displayed only when I configure it manually again...
