UnrulyUngulate
Hi
Noticed this behaviour starting after I flashed from PinnaclePI to the ComboPI based BIOSes back in June whilst still running a 2600X.
Further to HWinfo sensor monitoring locking up, the system will no longer power down properly. Windows will shut down, but system fans keep spinning and system power on led remains lit.
I have to force power-off by holding in the power button or flicking the switch on the power supply.
After a reboot, everything is functional again until the point I run HWinfo after the system has already returned from sleep (HWinfo fails to start), or the system wakes from sleep whilst hwinfo is running (HWinfo sensors are frozen after the system waking up).
Sometimes, killing the svchost.exe process in the wait-chain under HWinfo allows it to spring back into life with the sensors updating properly, though attempting this a second time just leaves the application unresponsive and in a state where it can't be terminated.
All of the ComboPI BIOSes I have tried to date (including the current 5204 from 31st July), cause HWinfo sensor monitoring to freeze if the system has gone to sleep and then returned from sleep.
Same behaviour with Ryzen 2600x and now on a new 3600x. Exactly the same behaviour on a different system built recently for a friend, also using a Prime X470 Pro and a 3600X.
Someone else commented on experiencing the same thing with a Prime X470 Pro after I posted about the issue on a different forum.
So far, this behaviour seems to be particular to HWinfo, and only after having changed from Pinnacle PI to Combo PI firmware.
The system otherwise has no problems with sleep, and neither do any of the other sensor monitoring applications I've tried to date.
This is a particular pity, since HWinfo has been my go-to monitoring application for years.
Let me know if you need a debug dump.
