HWiNFO v6.43-4370 Beta released
HWiNFO v6.43-4370 Beta available.
Changes:
  • Enhanced sensor monitoring on MSI H510 series mainboards.
  • Fixed monitoring of +12V on some ASUS Z590 series mainboards.
  • Improved support of LPDDR3/LPDDR4/LPDDR4X memories.
  • Fixed a possible WHEA error/system crash during long-term monitoring of AMD RX 6000 series GPUs.
  • Enhanced sensor monitoring on ASRock Z590 Taichi and Z590 PG Velocita.
  • Consolidated AMD Navi monitoring, added Effective Clock and TGP Power for Navi21.
  • Added sensor tool tips to provide more details about sensors and their values.
Zach
Great job Martin on the tool tip details! Thank you for this
Just a heads up. Some tips are going off screen and when you use full screen window of sensors mode and you cant read a part of the details.
EDIT: typo
Thanks, I hope that this feature will help many users to better understand the meaning of several sensors.
Will have a look at positioning of the tooltip...
VictorVG
Then update up to v6.43.4370 in to OS I find old HWinFO64 drivers have display name:
HWiNFO Kernel Driver (v150)
HWiNFO Kernel Driver (v151)
HWiNFO Kernel Driver (v152)
HWiNFO Kernel Driver (v153)
HWiNFO Kernel Driver (v154)
HWiNFO Kernel Driver (v156)
and in to %WINDIR%\System32\driver unused drivers:
HWiNFO64A_150.SYS
HWiNFO64A_151.SYS
HWiNFO64A_152.SYS
HWiNFO64A_153.SYS
HWiNFO64A_154.SYS
HWiNFO64A_156.SYS
then delete it manually
Question:
Is it possible to add a dialog procedure to the HWiNFO code that performs operations
sc stop HWiNFO Kernel Driver (v ***)
sc delete HWiNFO Kernel Driver (v ***)
del /f /s /q HWiNFO64A _ ***. SYS> nul
for old drivers found in the OS? In theory, this is just garbage that wasted system resources.
HWiNFO64A_150.SYS
HWiNFO64A_151.SYS
HWiNFO64A_152.SYS
HWiNFO64A_153.SYS
HWiNFO64A_154.SYS
HWiNFO64A_156.SYS
Question:
I guess you're using the installer version that you haven't uninstalled or have the Persistent Driver option enabled. With the portable one such traces should not remain.
VictorVG
Yes, the Persistent Driver option is enabled. Habit. :) Okay, if I clean something with my hands, it's not difficult.
