HWiNFO32 and HWiNFO64 v4.05-1740 Beta released
HWiNFO32 v4.05-1740 Beta and HWiNFO64 v4.05-1740 Beta available.
Changes:
  • Enhanced sensor monitoring on ASRock Z77, Z75, H77, B75, Q77, H71M and A75 series.
  • Minor bugfixes and improvements.
  • Driver management tool removed from package. Functionality moved into Configure section.
  • History file removed from package. Available online in the News section.
  • Help file replaced with on-line help (forum).
  • Embedded all supplemental files (DAT, drivers) into the main EXE file.
  • Reduced package content to 2 files only (EXE, INI).
  • Added reporting of GPU VDDC for later AMD GPUs.
AndreDVJ
I use HWiNFO mainly as a sensor only application. I just start everything minimized and I forget the summary is there. Now choosing Sensors Only at startup cut memory consumption in half, from 16MB to 8MB.
[*]Added reporting of GPU VDDC for later AMD GPUs.
Yes it now works. My GPU is a Radeon HD6950:
404 and 405 side by side:
Good job sir! Really nice improvement.
