Yincognito
Ok, thanks. It doesn't bother me that you have identical GPUs. In fact, it's better, as it should be "harder" to tell which is which. I want to check my method against "stronger cases", not easy ones.
Anyway, the PNPDeviceID from the wmic command should be different from one GPU to another, although the GPUs are identical - that's why I included that in the command.
I don't care which one is primary. I only care about the order in which they are displayed. To be more specific, I'm displaying both GPU's data, regardless of the primary/secondary status, so my concern is only about "correlating" the grabbed info to the correct GPU.
P.S. When you have the time to try the posted wmic command, could you please paste wmic output here or link to a screenshot? I hope I'm not asking for too much, but I'm really interested in how much info is different in the case of identical GPUs (e.g. if also the name of the GPU differs - usually Windows appends a "#number" to same name devices).
Thank you again for your patience and willingness to help.
so it's not easy to tell exactly which one is primary
