Known Compatible PSU's with HWINFO64
bamckellar
Hi, i have searched and can not find and answer. I do know that the Corsair AX1200i will show in HWINFO64. This PSU is quite pricey and im looking for a less expensive option. I will not be using Icue or anything like that. The PSU will plug straight into the internal USB connection. Does anyone have a list or know of other brands or models that will show in HWINFO64?
Thanks for any help.
Currently the following PSUs are supported for monitoring:
- most Corsair series (AX/HX/RM), but monitoring of some of them is not quite reliable
- Thermaltake DPS series
- Enermax Digifanless
Zach
Yes those are, but the monitoring capable ones are the (i).
AXi, HXi, RMi. I have HXi750.
