Lenovo [Unknown Model: LEN418A] is "Wide viewing angle & High density FlexView Display 3840x2160"
Also can added and HP 22fw (have HDMI input only). Parameters and URL
HWiNFO64 v8.15-5595 Beta show:
General Information
Monitor Name: HP [Unknown Model: HPN3541]
Monitor Name (Manuf): HP 22fw
Serial Number:
Date Of Manufacture: Week: 18, Year: 2018
Monitor Hardware ID: Monitor\HPN3541
Max. Vertical Size: 30 cm
Max. Horizontal Size: 50 cm
Horizontal Frequency: 30 - 86 kHz
Vertical Frequency: 48 - 75 Hz
Maximum Pixel Clock: 180 MHz
Advanced parameters
Input Signal: Digital
Gamma Factor: 2.20
DPMS Modes
Standby: Not Supported
Suspend: Not Supported
Active Off: Supported
Standard Colour Space (sRGB) Default: Not Supported
Preferred Timing Mode: Supported
Default GTF (Continuous Frequency): Not Supported
DFP 1.x Compatible: No
Supported Video Modes
1920 x 1080 60 Hz
1600 x 900 60 Hz
1280 x 720 60 Hz
1680 x 1050 60 Hz
1440 x 900 60 Hz
1280 x 800 60 Hz
1280 x 1024 60 Hz
1920 x 1080 476 x 268 mm, Pixel Clock 148.50 MHz
Specification list copy at HP support page: https://support.hp.com/kz-ru/product/product-specs/hp/model/20925630
Display size (diagonal) 54.61 cm (21.5")
Aspect ratio 16:9
Resolution (native) FHD (1920 x 1080)
Resolutions supported 1024 x 768;
1280 x 1024;
1280 x 720;
1280 x 800;
1366 x 768;
1440 x 900;
1600 x 900;
1680 x 1050;
1920 x 1080;
640 x 480;
720 x 400;
800 x 600
Pixel pitch 0.247 mm
Brightness 300 nits
Contrast ratio 1000:1
Response time (typical) 5 ms gray to gray (with overdrive)
Product color White
Onscreen controls Brightness;
Color control;
Contrast;
Exit;
Image control;
Information;
Input source;
Language;
Management;
Menu;
OK;
Power
Display features Anti-glare;
Anti-static;
In plane switching;
Language selection;
LED backlights;
On-screen controls;
Plug and Play;
User programmable
Physical security Security lock-ready
VESA mounting Not VESA mount compatible
Camera No integrated camera
Minimum dimensions (W x D x H) 48.98 x 3.97 x 29.67 cm
Package dimensions (W x D x H) 56.8 x 13.2 x 38.7 cm
Weight 5.14 lb
Package weight 4 kg
Power Input voltage 100 to 240 VAC
Power supply type External
Power consumption 21 W (maximum), 19 W (typical), 0.3 W (standby)
Operating temperature range 5 to 35 grad C 41 to 95 grad F
Operating humidity range 20 to 80% non-condensing
Ecolabels ENERGY STAR certified
Sustainable impact specifications Arsenic-free display glass; Mercury-free display backlights; Low halogen
Certifications and compliances BSMI;
CB;
CCC;
CE;
CEL Grade 2;
CSA;
CSA-NRTL;
EAC;
E-standby;
EUP Lot-6;
FCC;
GEMS;
HRN N N0.201;
ICES;
IEC 60950-1;
IS 1121;
ISO 9241-307;
KC;
KCC;
MEPS;
Microsoft WHQL Certification (Windows 10, Windows 8 and Windows 7);
PSB;
RCM;
SABS IEC 60950-1;
SASO;
SmartWay Transport Partnership (NA);
TUV Bauart;
VCCI;
ISC;
Low blue light
Manufacturer Warranty 1 year limited warranty
What's in the box HDMI cable;
Documentation;
Warranty card;
Set up poster;
Power adapter;
AC power cord
Tech spec footnote
[1] All specifications represent the typical specifications provided by HP's
component manufacturers, actual performance may vary either higher or lower.
Tech spec footnote
[2] External power supplies, power cords, cables and peripherals are not Low
Halogen. Service parts obtained after purchase may not be Low Halogen.
Tech spec footnote
[3] Lock is sold separately.
p.s.
I do not want to start a new topic, and I hope that you will not object if I add specifications and my monitor to this one. In advance, when I apologize for possible inconvenience.
fix typo
