Low "Power Deviation" on Ryzen 5 3600
Torse
Hi, i recently noticed my CPU shows solid 81% power deviation value when doing Cinebench-R23 multicore stress test. This scares me a lot cause in the tooltip says under 90% its cause of concern. Both my CPU and Motherboard are in warranty but i wanted to know if it's worth to ask for it. I run stock BIOS options (Except 3000 mhz ram profile) and i have a ryzen 5 3600 that goes to 4200mhz on max frecuency core clocks (Stocks settings) + B450 Aorus Pro. I dont have any temperature problems (Stress test dont reach 80 degrees, also MoBo Bios is fully updated)
I have read almost every post in internet about this topic but the information is very confusing, so i wanted to ask here directly. Sorry if it has been asked so much.
Any help is really appreciated. Thank you.
Torse
Ok, as far i understand it should not harm anything if temperatures are normal (Since the MoBo makes the chip go faster like if it were an overclock). Thank you so much.
Anyway, is there any way to fix it in BIOS? Or not worth trying?
