power reporting deviation %1100
Hello everyone, for a while while I was playing Euro Truck Simulator 2, the computer was suddenly shutting down after 10-15 minutes or after opening the game. At first I thought it was a Wattman error because I was using an AMD graphics card, but I realized that it was the same when I used a different graphics card. My power supply is new. I tried 2 separate power supply cables, opened the inside of the power supply and there were no burns etc. anywhere. My ram is solid, I did 2 separate tests and tried changing the slots. My SSDs are healthy because I just formatted them and checked them from disk healthr. There was no sudden shutdown when I put it to the OCCT test. This situation only exists in Euro Truck Simulator 2 and I only play 2 games. This happened occasionally in CS2. And when I looked at hwinfo, I saw that my "power reporting deviation" value was ridiculous, while it was under load or idle, I looked at the post in the forum, but my English is not sufficient and I could not understand it. If anyone has any information, suggestions or ideas about the solution, I would be happy if it could help me, because I am about to go crazy.
AMD Ryzen 5 2600 Altı Çekirdek 3.40 GHz İşlemci + Stock fan
RX6600 8GB (PowerColor)
Zoko ZK600 600W 80+ 12 CM Fanlı Güç Kaynağı
ASUS PRIME B450M-K II AMD B450 SOKET AM4 DDR4 4400MHz(O.C.) M.2 Anakart
Team T-FORCE NIGHT HAWK RGB BLACK 16 GB (2x8) 3000 MHz DDR4 CL16 TF1D416G3000HC16CDC01 Ram
Kingston SA400S372240GB : 240,0 GB
ADATA SU650 : 120,0 GB
I meant the Power Reporting Deviation with such high number. Your problem is most likely something else.
