Hello everybody.
I have a problems with my Computer and have been searching for a while for the exact source of the problem. So first I will tell you what is going on.
I noticed that my CPU throttles down everytime it has to do some work. After a while I figured out that it has to be something with the temperature of my PC, although every value I can see looks fine (except one, I will come back to that later). So I tried the tool "ThrottleStop" and turned of "BD Prochot".
What is BD Prochot?
"[font=arial, helvetica, sans-serif]BD PROCHOT stands for bi-directional prochot. PROCHOT stands for processor hot which is the signal that is activated within the CPU when it reaches approximately 100C to 105C depending on the model number. This signal is what initiates thermal throttling so the CPU can slow down and keep from over heating. Intel included a bi-directional feature so if something else like a GPU is running too hot, it would be able to send a PROCHOT signal directly to the CPU and force it to cool down so the entire laptop cools down. Very few laptops seem to use this type of throttling. This feature was added for the Asus G51. Disabling this will allow your CPU to continue to run at full speed. Disabling this will not prevent your CPU from thermal throttling at its normal Intel set thermal throttle temperature."[/font]
[font=arial, helvetica, sans-serif]Since I turned this off, the CPU runs just fine. So my motherboard seems to think, that something is too hot and wants to cool down the PC by throttling down the CPU.[/font]
[font=arial, helvetica, sans-serif]The big question is: Is something really too hot or is it a mistake? And here comes HWiNFO into play.[/font]
[font=arial, helvetica, sans-serif]I took a screenshot in the exact moment my CPU throttles down:[/font]
https://pl.vc/ym6jf
[font=arial, helvetica, sans-serif]Every temperature value looks fine except the one I marked. This value can`t be correct. The value jumps between 0 and 120 in seconds. [/font]
[font=arial, helvetica, sans-serif]So my question is: What does this incorrect value mean? Could it be a mistake made by the HWiNFO tool? Is a sensor on the board broken? Is it possible, that the board thinks it has to throttle down the CPU, because of this broken value?[/font]
[font=arial, helvetica, sans-serif]Yours Sincerely[/font]
What is BD Prochot?
https://pl.vc/ym6jf
