Max on Graphs
Zodler
I have seen graphs on other software like Asus GPU Tweak that also show min max on their graph. Very useful.
It would be a nice addition to see it directly in the graph window. Either having it on the title bar or on the right column of each graph.
With Auto Fit enabled, the Min/Max is show on the right side of the window.
Zodler
The Min/Max is completely separate functionality from Auto Fit.
1- You don't run Auto Fit on all graphs. You don't run it on CPU Usage, GPU Load, Fan Speed, Core Clocks, CPU Temperature, GPU Temperature and all the major sensors.
2- Even if you did turn on Auto Fit, the values on the right are min max of the current graph and not all time. The functionality should be the same as min max in the main window. The one that has no graph and shows all sensors. If it was to show only the min max of the current graph, it would be of no use, because you can already see it in the graph.
