Memory clock question
james41382
Hello, I have a X99-A/USB 3.1 board with a G.Skill DDR4 3000MHz kit and is set to use the XMP profile. I attached a snippet from CPU-Z and another from HWiNFO. CPU-Z shows the RAM frequency at 1500MHz, which is actually running at 3000MHz (DDR). HWiNFO shows the RAM clock at 1200MHz. Am I missing something or should 1200MHz actually be 1500MHz? Thanks in advance.
What is your actual BCLK?
Please attach the HWiNFO Report File and Debug File so I can check it in detail. It might be a bug...
james41382
BCLK is 125MHz. I have attached the report, but I don't know how to create the debug file.
  • NEOPHYTE.HTM
Thanks, the report file is sufficient in this case.
It's a bug in HWiNFO, which doesn't properly reflect BCLK overclocking in memory speed reporting. It will be fixed in the next build released.
james41382
Martin, I just upgraded to version 5.20-2800 and the memory speed BCLK issue appears to be resolved. Thank you!
