Motherboard: 38c but temp 3: 109c temp 4: 107c temp5: 104c
DCCFan
Hi, I'm a bit worried about temps 3, 4 and 5. But surprised by the first temp reading 38c which is pretty low. What does this mean? I'm a bit of a newbie. Motherboard is Asus z170-k and seems to be working very well otherwise. Build has the 6600k and rx 580 if this helps in any way. Thanks!
Those values (Temp3-5) are most probably invalid readouts from not connected sensor inputs. No need to worry about that, just ignore them.
