Mouse Cursor Bug
savgiorgos5
I always have open only the sensors, minimized.
How to get report file and debug file?
I have an MSI RX 470 4GB, and I updated my gpu drivers to 17.7.2, 1-2 days before this issue occurred
savgiorgos5
okay this solved it, but will you fix this in the future? I want to know my gpu rpm through my rainmeter skin
I tried to get this debug file anyway but I couldnt make it, it says "Then continue with the scan process" what scan process? I didnt find anything in the installation folder or documents..
OK, so the problem is actually in the AMD Radeon Software 17.7.2. You're not the first user that's reporting this.
I'm communicating this with AMD...
