trodas
As Martin undoubtely noticed, I recapped this old interestingly designed MSI 6340 mobo:
http://www.hwinfo.com/forum/Thread-MSI-6340-recap
...so I run a HWiNFO on it...
And it does work, but it freeze on the sensors screen, not showing them at all. No idea why. What makes this all even more interesting is, that MSI claims that the mobo does not have sensors.
The problem - with bios v4.0 I seen the sensors and their output in the bios. The catch? In v4.7 bios they are gone. I could be mistaken, but there is screenshot from ModBin that show, that the menu there exist in the old bios version, so I'm not making it up:
Anyway, used latest HWiNFO v4.25-2013 and as I say, it run:
It just freeze when I click on the sensors (it scan the sensors, took it's time and when the little scanning windows close, then it freeze and cannot be exited, not even terminated by taskman - and not even by procexp can the HWiNFO be terminated, witch is quite unusual and make me worry...), so... Everest run and even show "sensors" - just the HDD. Suxx
Because I did this before, then I include in the attachment:
- CPU-Z report
- Everest report
- HWiNFO report
- HWiNFO debug when I hit the sensors
I believe that this is all what one can supply. Now if you excuse me, I would take a look what software can modify the FSB on KT133 chipset on the run, so I can score some overclock results for HWbot:
http://hwbot.org/hardware/motherboard/ms-6340/
3DMark 2001 is not enought
PS. bugging Franck about this mobo too, as the latest CPU-Z (1.66.1) did not show FSB on this mobo and futher testing reveal, that oder version (1.61.3) does. And even futher testing reveal, that same situation is on KT266A chipset mainboards and what is worser, on KT600 mobos the CPU-Z (both 1.66.1 and 1.61.3) freeze the mobo! Old version 1.38 work fine on the KT600 (Soltek mobo)... So if you happen to got any FBS ideas - feel free to share. FSB (100MHz) is well detected. Ram clock is FSB+33, usually, depends on bios settings.
Overclocking in bios does not work, each value end up by running at FSB about 30MHz - ane believe me, 256MHz Duron is somewhat slow
- CPU-Z report
- Everest report
- HWiNFO report
