No Menu
I installed the program and when I click on Summary I get a screen with all of the information on my computer in it.
Unfortunately, there is no menu to either save it or log it in anyway. How do I do that?
Thanks
Information from the summary window can only be copy-pasted by each item, or you can take a screenshot using Alt-PrtScr.
If you want to save all information into a file, you can create a Report File from the main menu.
Thanks for the quick response.
I guess I wasn't clear about the screen. I only get the summary window. There is no main menu at all either with icons or text. I cannot create any report or log file.
When I open the program I only get a small dialogue box with the choices of sensors or summary. There is no menu here either. Your website screenshots show a lot of different views plus a main menu. I don't get any of that.
Then you will need to disable the "Summary-only" option in the initial dialog box.
Note that if you have both Sensors-only and Summary-only not checked this means you will get all the features. Selecting either of those options will limit HWiNFO to show the chosen mode only.
