Not autostarting
robinmorgan
Auto start is not working on my Snapdragon 8 elite laptop. I think it has something to do with HWiNFOLauncherARM64.exe when I run that file nothing happends. Only when I run HWiNFO_ARM64.exe itself HWInfo runs fine, but tried every single way to get that file to autostart but seems impossible as to to why probably the launcher file is created when you enable auto start, but yeah that executable doesn't run anything.
Check in Windows Task Scheduler if there's a HWiNFO task and if yes, try to run it manually.
Running the HWiNFO task manually does not start the program for me either. Task Scheduler does say it is running, however no process appears in task manager.
I just use shortcut in to ./Start Menu/Programs/Startup and all working success. Possible this local OS error...
