Nvidia GTX470 allocated Memory doesn show up in Sidebar gadget
nuggibert
Since I upgraded to the newest version of HWinfo 4.46-2330 the allocated memory of my GPU doesn't show up in die HWinfo Monitor Sidebar gadget.
In HwInfo it shows up in the sensor list and monitoring is activated. But it doesn't show up in the config dialog of the gadget. Shared memory is of cause activated in the HWInfo settings.
I use Nvidia driver 344.11 on Windows 7 x64 Sp1
Also Network throughput doesn't show up in the gadget any more.
I deleted the two files in C:\Users\username\AppData\Local\HWiNFOMonitor and started a new config.
  • HWiNFO32.DBG
  • report-nuggibert.HTM
I have notified the author of the HWiNFOMonitor gadget, he should give a better answer.
stangowner
Moderator
Yes, there appears to be some issues with 4.46. I'm looking into it and will reply back soon when I have more info.
- Nick
