HW Info not showing my main GPU temp - Help
Bananaman
Programs like GPU-Z or HwMonitor don't have a problem at all reading the GPU Temp. But hwinfo does! I just don't know what I'm left to do.
I have my Asus rog strix 3090 on newest nvidia driver and also use the newest hwinfo (also tried older versions, also tried beta versions, also tried reinstalling everything).
Weirdly this "bug" occured after I disabled the 2nd GPU (of my 7900x3D) in the BIOS. After the problem arose, I switched it on again though. So all back to normal. If I switch it off again in the device manager, the problem is still there. So doesn't matter if my integrated graphics is on or off.
I'm kind of frustrated now. Tried so much.
I need the GPU temp for my readings with my streamdeck.
It is the most important parameter in my streamdeck readings^^
as you can see HW info doesn't show my GPU temp, hence my streamdeck can't show it which is a huge bummer, since I really want to see it on there.
But HW monitor has no probleme at all reading the sensors:
Have you maybe unintentionally hidden that value? Check in sensor settings under hidden values or try to do a Restore Original Order there.
Dudeee, thanks so much!
That was it. Didn't even notice there was an option like this. Even after resetting apparantely it still had those values hidden. Weird.
Goes to show it is once again the user not the machine :D
