TheRealHendrix
I have a Lenovo Y740 laptop with a 9750H integrated GPU (Intel UHD Graphics 630) and an RTX 2070 Max-Q dedicated GPU. When I turn on Optimus / Hybrid Mode, my iGPU is successfully running instead of the 2070MQ. In HWinfo64, it lists my 2070 as GPU #0 when Optimus is off, and GPU #1 when Optimus is on. However, it does not show my iGPU Intel UHD Graphics 630 listed as GPU #0. I see the iGPU voltage and GPU clock speed listed under CPU, but I don't see the rest of the monitoring sensors where GPU #0 should be.
Is there anything I can do to try and get HWinfo64 to detect my iGPU Intel Graphics 630 as GPU #0. It seems to simply be missing for some reason. I'd like to be able to monitor the graphs from the sensors when I am not gaming with my dedicated RTX 2070 Max-Q.
When I had a Y740 with a 8750H and Optimus on, HWinfo64 listed my iGPU as GPU #0 and my RTX 2060 as GPU #1. However, with the 9750H the iGPU is not being detected as GPU #0 with Optimus on. Are there any settings or troubleshooting I can try to get HWinfo to list my iGPU in the monitoring list? I'm not sure exactly what to try, the settings are all pretty much stock. I've tried enabling/disabling Optimus and restarting my PC, and also restarting HWinfo64 with administrator before I restart my PC.
Please let me know if this is a known bug with the 9750H's Intel UHD Graphics 630, and what I can try to get the monitoring sensors to be detected. the iGPU is definitely in use, because I can see the iGPU watts and clock speed listed under the CPU monitoring sensors. Also, if anyone has Optimus/Hybrid Mode, please let me know if HWinfo64 detects your integrated GPU when it is turned on. Thanks a bunch!
