Samsung ATIV Tab 7 XE700T1C-K01US fan control
edlu
I used to work with my Hp 2740p, and HWiNFO supported fan control.
I just got a Samsung ATIV Tab 7 XE700T1C-K01US, can you add support for Atvi Tab 7?
Or what info do you need?
Right now, Hwinfo does not list fan speed at all.
Motherboard Model is Samsung ATIV Tab 7 XE700T1C-K01US
Motherboard Chipset: Intel HM76 (Panther Point)
Fan is driving me crazy.
Thanks a lot
edlu
Do you know any other 3rd party software that can do fan control? I tried speefan - does not even find the speed, I am having issues to run on 64bit Dell utility I8kfanGUI.
Samsung has a fan control option, supposedly to do that. It is a crap comparing to HWiNFO.
I don't think there's any other tool than own Samsung's, because the method to control fans is nothing standard, but something proprietary.
