VIN6 is not DRAM voltage - I tried to change DRAM voltage in BIOS from 1.8V to 2.0V but VIN6 value has not been changed.
According to datasheet on W83667HG it has 8 voltage inputs (CPUVCORE, VIN[0..2] and 3VCC, AVCC, 3VSB, VBAT).
VIN[0..2] inputs mensuare 0..2.044V range and I suppose that they are used for meansuring via voltage divider 12V, 5V and 5V standby values(last item is shown by Aida64 so I think that it is taken from one of these pins). Because of this I think that VIN6 is one of the following: 3VCC, AVCC, VBAT(taking into account that 3VSB label is corresonded to its value). Also please note that HWiNFO shows two different 3.3V values with the same label "+3.3V", so one of them should be also changed to avoid confusion.
Could you please add all other voltage values from this sensor to HWiNFO(I mean that it would be nice to have: +12V, +5V, +5VSB, CPUVCORE, 3VCC, AVCC, 3VSB and VBAT) and correct incorrect "+3.3V" label?
P.S.: Please see the datasheet in the attach.
Thanks a lot.
