Nah, i only use them in sessions (they are too taxing, as their reporting speed about 10-20 refreshes per second). And when i use them i don't care much about HWINFO readings, as they are used for instantenous values. (And they really mess up HWINFO in terms of max clock readings. I saw up to 56.5 gHz on max frequency few times, and i know it is not true)What do you mean with "2 deep CPU monitoring tool"? Are you running multiple monitoring tools alongside? If yes, the problem could be due to a conflict between them.
HWINFO on other hand misreports 0 mHz clocks consistently and randomly even without them being enabled.
Only things that can potentially affect HWINFO are MSI Afterburner and AMD Adrenaline software? And i kind of sorted out that installing Adrenaline without RyzenMaster component won't affect HWINFO.
And MSI Afterburner had no effect on HWINFO at least up to some point.
Hmm... I will try to check CPU monitoring off from Afterburner (I use it for overlay data)
