integral
The GPU Chip Power sensor always seems to freeze at least once a day.
Restarting HWINFO seems to fix it, but I'd rather not have to do that multiple times a day.
I usually idle at around 34W GPU Chip Power, but for some reason it's stuck at 74W.
I had to play around with HWINFO settings to get to the main window to be able to create a report. I don't know if that would affect anything though.
Also, VDDCI (labelled as VDDC2 in screenshot) doesn't seem to be the auxiliary/memory controller voltage.
http://greentechreviews.ru/2015/10/23/obzor-videokarty-asus-radeon-r9-380-strix-gaming/
http://cxzoid.blogspot.com/2017/02/asus-rx-480-strix-oc-review.html
The real aux voltage is controlled by a uP1540P, but I have no clue what voltage VDDCI in HWINFO is referring to. Increasing it helps with core stability, so it's possibly one of the core phases. I don't have a DMM to verify, nor do I know what to do with it if I had one, so this may be a moot point.
