System tray icons problem on Windows 11
Maouk
Hello, I have a problem with the tray icons. Every time I turn my PC on, the GPU / CPU temp icons hide (sometimes just one, other times both of them) and when I check the "other system tray icons" menu, I see multiple entries. See attached screenshot.
Do you know how to fix this?
I'm sorry I don't know how to fix this. Notification (tray) icons are completely managed by Windows, applications cannot specify which ones are hidden or shown.
Thank you for the reply. Do you think it could be caused by incorrect entries in the registry? I'm wondering if I should uninstall, remove any "Hwinfo" entry in the registry, and reinstall it...
You can try to "Clear Preferences" in HWiNFO and setup the items again but I don't think that will make a difference.
