T1 Temperature
fadsarmy
Hello
Is T1 temperature reporting VRM temperature on MSI Z270 Gaiming Plus motherboard?
For the Z270 Gaming Plus model, the T1 value is most probably the CPU socket temperature.
But try the latest HWiNFO Beta version (v5.93-3610), this should report independent VRM temperature straight from the VRM (if supported by the VRM and SVID is enabled). Check under the CPU sensor.
fadsarmy
Hi Martin, I used v5.93-3610 but could not locate the VRM temperature like others have reported. Am I missing something?
The VR used might not be capable of monitoring its temperature.
Please attach the HWiNFO Debug File and I will check that to be sure.
fadsarmy
Here we go.
  • debug.zip
fadsarmy
Isn't it strange some people with the same board report VRM temps? Is MSI using different vrm's on the same boards?
Some vendors do such tricks, not sure about MSI.
I'd need to see the HWiNFO Debug File of such a system.
It might be some sensor placed on the mainboard close to VRM, but I don't think it reflects the true VRM temperature.
