Temp#3 issue
Geoward.01
Can someone Please help me?
My new build has a temperature issue causing it to shut down. It’s been running fine for two months.
The CPU temps are fine.
The temperatures for the motherboard are as follows:
Temp#1=45
Temp#2=45
Temp#3=95 and higher
The computer specs are:
  • Ryzen 9 -9900X
  • GIGABYTE B650 Motherboard, Gaming X AX AM5, PCIe4, M2
  • EVGA RTX 3070ti
  • Crucial Pro DDR5 RAM 32GB Kit (2x16GB) CL36 6000MHz Memory
  • Be Quiet Pure Loop 2 240mm Water Cooling System
  • (3) Samsung, 980 Pro, SSD, 2TB, PCIe4, M2-2280
  • (1) SSD, 1TB
  • 700W Power Supply
Thank you-
I already pulled the water cooler so I can't provide the screenshot.
After further research it looks like the brand of water cooler I used may be causing sensing issues with hot & cold spots.
So I am going to change to a Noctua NH-D15 air cooler.
I will keep you posted.
