Currently using RealTemp GT to monitor both my CPU and GPU, also use MemReduct to monitor memory. I also use HWiNFO just so I can utilize a desktop gadget... but want a small memory footprint, and discard of two applications.
Question is:
I'd like to supplement both of these utilities with HWiNFO, but the application doesn't display memory as a percentage rather the physical available/used which I prefer the later. Also, RealTemp displays the average of all cores as the true temp and lists each core temp in a tooltip when hovering over the tray icon. RealTemp also displays GPU temps, and since I have two GPU's it displays the average of the two as the temp and also lists each cards physical temps in a tooltip. I like RealTemp since it provides detailed information in a condensed form in the tray, which HWiNFO doesn't seem to provide, but if HWiNFO can provide as much info as condensed.. then I'd be willing to part with it. So... is there any way to display the information I prefer to view by using HWiNFO?
Question is:
