Units Not Being Displayed
Airith
The recent update to HWiNFO has caused my gadget to no longer display units. Please see attached. When I look in the prefMonitors_0.json file, the units/modUnits values are empty. Any ideas?
Do you remember which HWiNFO version have you been using before the update ? Also which version of HWiNFOMonitor are you using ?
Airith
The last version that was working was hw64_520, I believe it was something in hw64_522 that caused the problem. It's not fixed as of hw64_524.
I'm using version 2.0 of HWiNFO Monitor (at least that's the last thing in the About tab of the options menu of the gadget, not sure if there's a way to find a more specific version).
Are all units missing there, or only some of them ?
Do you see units displayed in HWiNFO sensors screen ?
Are you perhaps using some special configuration in the HWiNFO sensors screen ?
Airith
All units are missing.
The units are displayed in the HWiNFO sensors screen.
I don't think I'm using any special configuration in the HWiNFO sensors screen. The only thing I've changed is hiding some of the sensors I don't need to see.
Airith
Hmm, that's strange. I have verified HWiNFO and it should be properly reporting the units.
First you might try this tool: www.hwinfo.com/files/RainmeterPlugin/HWiNFOSharedMemoryViewer.exe if you can see the units there.
Also it might be worth to try to start from scratch - reset preferences in HWiNFO and reconfigure the values in HWiNFOMonitor.
I've attached an image of HWiNFOSharedMemoryViewer.exe, there's no units in the text field.
Can you please try to reset preferences in HWiNFO if that will fix the problem ?
Airith
I clicked the Reset Preferences button in HWiNFO, restarted it, and restarted HWiNFO Monitor, still no units displayed.
I'm sorry, but I cannot reproduce this problem. We will have to wait for stangowner, the author of HWiNFOMonitor.
Airith
Thanks for looking into this, hopefully stangowner hasn't disappeared as it's been a month since he was last on.
stangowner
Moderator
I can't reproduce this neither.  Let me see if I can maybe add some verbose debug output to help narrow it down.  I'll reply back.
MadMax1337
Hello. I just had the exact same Problem and was able to find what is causing the problem.
In the HWinfo32 Sensor settings, if you remove the checkmark at "show colums - show average" the units in the gadget disappear.
Setting the checkmark again will also display the units again.
Maybe that helps. :)
And also thanks for this great gadget, works like a charm and it looks really nice. Great work.
Airith
I just wanted to confirm that this solved the problem, thanks @MadMax1337! I had to restart HWiNFO after checking the checkbox too.
MadMax1337
Great! I am glad it solved your problem.
I was lucky to notice the missing units a few minutes after changing just this one checkmark, so it was easy to redo in my case.
stangowner
Moderator
Nice find.
Martin, I can confirm the same is happening to me.  Here are the results I am seeing:
BEFORE
System: 0 - Reading 12 of 138
Reading Name Orig: Core #0 Clock [ 43 6F 72 65 20 23 30 20 43 6C 6F 63 6B ]
Reading Name User: Core #0 Clock [ 43 6F 72 65 20 23 30 20 43 6C 6F 63 6B ]
Sensor Index: 0x1 [ 01 00 00 00 ]
Reading ID: 0x6000000 [ 00 00 00 06 ]
Reading Type: CLOCK [ 06 00 00 00 ]
Units: MHz [ 4D 48 7A ]
Current Value: 798.101143 [ 3C CE 3C 24 CF F0 88 40 ]
Minimum Value: 798.085800 [ B4 A1 05 B8 AF F0 88 40 ]
Maximum Value: 3029.428089 [ 05 73 7A 2E DB AA A7 40 ]
Average Value: 1019.089585 [ 8F 2D 2F 78 B7 D8 8F 40 ]
AFTER
System: 0 - Reading 12 of 139
Units:  [ ]
Current Value: 798.057297 [ D6 B6 62 58 75 F0 88 40 ]
Minimum Value: 798.024574 [ 23 E9 1A 54 32 F0 88 40 ]
Maximum Value: 3491.769572 [ 57 55 64 05 8A 47 AB 40 ]
Average Value: 1215.333514 [ 64 3E 90 84 55 FD 92 40 ]
So it seems removing the average column is causing the Units value in shared memory to be unreadable for me.  Is a null being written there?  Its not causing a shift of bytes at all as the cur/min/max/avg values are all OK.
Oh indeed !
Found the bug, shall be fixed in the next (Beta) build.
Thanks for the tests and workarounds !
