What for this need ?
Hi , each new versino HWinfo add problem , problem in so add new drivers in Windows , for example
HWiNFO64A_150.sys
HWiNFO64A_151.sys
HWiNFO64A_152.sys
HWiNFO64A_153.sys
HWiNFO64A_156.sys
HWiNFO64A_160.sys
HWiNFO64A_161.sys
HWiNFO64A_163.sys
HWiNFO64A_164.sys
HWiNFO64A_165.sys
HWiNFO64A_167.sys
what for this not remove from drivers ?
This happens only if you have the "Persistent driver" option enabled and don't uninstall the previous version.
The old driver is not automatically removed as it's not known whether some other application might be using it.
You can safely delete the old versions.
