What is gpu memory usage?
CoderOutsider
Sorry for my English because I'm from another country (I'm using google translator).
Thank you in advance for the answers. I'm playing Apex legends at the maximum settings. I have 2x8GB of ram. In hwinfo64 is showing that I got to use 11409mb of gpu memory usage, but my rx580 only has 8gb ... is this a bug? in the gpu d3d memory dedicated shows that I used 7824mb, which is right since my card has 8gb. What is the difference between gpu d3d memory dedicated and gpu memory usage?
.extraClassAspect { -webkit-transform:scaleX(1.34)!important; }.extraClassCrop { -webkit-transform:scale(1.34)!important; }
That looks like a bug in GPU drivers, GPU Memory Usage should be reporting a value similar to D3D Memory Usage in this case.
Try to upgrade the GPU drivers to latest version if that will fix it.
