Dave1001
I monitor both the SVI2 TFN and Vcore for my 5800x; both of which obviously fluctuate under load. the SVI2 TFN is typically within 1.2-1.4v, while the Vcore can be a bit more 'reactive', I guess? for example, I will often see the Vcore in the 1.2-1.3v range, while also dropping down into the 1.1v's, and even a solid 1v sometimes
why is this? is there a reason the Vcore drops a lot more compared to the SVI2 TFN (which as I understand, is the VDDCR voltage). under load it likes to specifically drop to occasionally to 1.184v before going back up. am I risking any kind of instability or facing a symptom of some problem with this behavior or is it a harmless drop in voltage caused by the way the motherboard/CPU handles itself?
I have no overclock; just Eco Mode 65w enabled
