Wrong +12V Reading
Miasmus
Hi there, i'm new here, since i see forum is active, i would like to mention a bug here.
I downloaded HWinfo 64bit to read my +12V under load. Its not that important but i was curious about it.
HWinfo shows +12V is 1.672 which is wrong. So i checked it on BIOS it is 12.232V.
Since i'm not able to see BIOS while system is under load (windows+programs running), i cant read +12V. Is it possible to fix this issue?
MOBO: MSI B85M-E33
Sensor: Nuvoton NCT6779D
These infos already on screenshot
BIOS voltage readings:
VCCIN: 1.744 (same as HWinfo)
+5V: 5.120 (same as HWinfo)
+12V: 12.232 (HWinfo shows 1.672 which is unrealistic)
Note Screenshot is taken on High Performance power mode (which doesnt downcloak my CPU while IDLE since its same on BIOS screen)
I hope it will be fixed soon, keep up the good work, thanks...
Thanks for your report. This bug will be fixed in the next HWiNFO (Beta) build.
