Z77X-D3H/Z77X-UP5
So UP5 with the latest BIOS still requires the +18C offset ?
I don't know now, whether to remove that offset only for Z77X-D3H...
stasio said:
UP5 display correct (1842).
Yea,no change so far.
Attached UP5 sensor page.
Later today I'll check on D3H.
Rgs
Martin,
just checked my D3H and all OK.
ET6,AIDA64 and HWiNFO (1842)...PCH excatly same temp.
Thanks. Now this is strange, since preacher65's Z77X-D3H doesn't seem to use the +18C offset. Do you have the same BIOS version as he does ?
stasio said:
Martin,
Yea,I must admit that GB change PCH temp in the newest Z77X-D3H BIOS.
As my daughter using D3H with my special modded BIOS (from UD3H),PCH temp reading correct,which is not applicable
for ordinary users.
So,yes Martin for Z77X-D3H, you can remove + 18 offset.
P.S.
If possible please inform Miklos and Ray,thanks.
OK, I'll remove that offset. Now the question is where's the truth and why the guys from Gigabyte play such a game...
I'd say that the offset shouldn't be applied at all, but when I remove it, users with older BIOSes will not get values consistent with ET6.
