So after getting fan over-ride to work, (Dell XPS 1702x) I encountered an issue where videos and audio would halt and buzz at intermittent times...
It was easy enough to determine if HWInfo was halted, problem went away..... but I wanted the benefits of fan control... that HWInfo gave...
Instead of hollering for help, I started reading the Known Issues and other help files... By taking the time to read those help files and then taking the time to learning where the items to disable were located in program (Layout), I eventually determined how to get videos to play smoothly with no random audio buzzes.....
In my case (Dell XPS 17 702x) the specific sensor was located in:
[DELL EC: DELL Dell System XPS L702X] BOTTOM CPU sensor under that... Changed both to NO from YES monitoring...
EDIT Bottom Listed CPU only.... However, This does seem to kill the fan display in Systray... And until I can find a way to keep both going, I won't know that fan control is solid...
THANK YOU For those help files!!!! YES!! I read them!!
