AMD Adrenalin 23.3.2 Driver removed a bunch of sensors and data from HWINFO64 on 7900XTX
G5y
Hi @Martin,
I just installed the new driver and a bunch of sensor data is missing.
Seems AMD changed something, or at least I hope that they didnt forget something :D.
Edit. GPU Front End Clock is shown but always reporting 0
Tried with latest stable and beta HWINFO64
I have decided to go ahead with the new Beta release sooner than planned as this was an important update.
Build 5020 was just released, enjoy ;)
Appears to be fixed to me! XFX 7900 XTX Merc 310 running 23.3.2. Thanks!
Can confirm for the 7900XTX MBA too. Wonder what AMD changed.
Thank you!
Heey Martin,
got a similar issue like the threadstarter. Bunch of sensors were failing or missing like all consumption-infos or the mem-temp with the old beta 5010.
Now with the new 5020 its all back but it seems there is a new bug. Framerate shows only 1fps all the time. With the 5010 it worked.
Where can i find the debug-info to post?
btw.. great program! using like years =)
edit: ah i found. do i need to open a game or smth like that?
