Asus EC sensors?
Kol12
Is it safe to monitor the Asus EC sensors on an Asus Maximus X Hero? These sensors usually show a warning but once not monitored the warning doesn't show again so I cannot remember what the warning is. Is it a conflict issue perhaps with Asus AI Suite which also monitors these sensors? These sensors include monitoring a thermal sensor cable I have plugged in. Another question if it is safe to monitor these sensors is what are the negative readings on the thermal sensor cable?
I don't recommend monitoring the ASUS EC sensor in case ASUS AI Suite is installed or running, this can cause conflicts.
Those negative values seem like an invalid readout also due to such a conflict.
Kol12
Ok thanks for clarifying. Can you tell me what the EC stands for? Will HWiNFO read and is it safe to read these board sensors if AI Suite is completely removed?
EC = Embedded Controller
I cannot give a 100% guarantee that reading this sensor won't cause some minor system latency issues, but from my experience on all recent ASUS systems there should be no problem. It there are some values that you don't need to monitor, I suggest to disable them.
We're also currently working with ASUS on an alternate method to read sensor values that will be fast and not suffer from any issues.
Kol12
Are you referring to specifically the EC sensors or other motherboard sensors? Are you saying that some of the EC sensors can be monitored without issues?
Wow sounds great!
Only the EC sensor. Yes, most EC sensors (and especially on ASUS mainboards) can be monitored without any issues. But it's not possible to know this in advance for a given system, each user needs to test this (for example if there are some hiccups while playing games and monitoring the EC sensor).
This behavior is unfortunately by design of the EC sensor and that's the reason why we're searching for a better solutions with ASUS.
Kol12
But you still don't recommend monitoring the EC sensors at all if AI Suite is installed? or can this be something the user can experiment with a sensor by sensor case basis? Is the latency due to monitoring software conflicts or is it an issue with HWiNFO monitoring the EC sensors?
No I don't recommend monitoring the EC sensor with AI Suite. Moreover, a lot of users don't recommend AI Suite at all ;)
I already explained that the problem with EC (including latency) is by design.
