This probably sounds crazy as hell, and HWiNFO may not be even be the culprit here, but please hear me out first.
End of April I built a new PC around the Ryzen 7 2700X, and everything was fine (and still is, mostly). On the first weekend, after playing some games for a while, I noticed temps were getting a bit hot. Shortly after, I realized all the case fans had shut down. The following day (probably Sunday or so) and the following weekends, it also happened. Always after I had the PC running for at least around 8 hours, sometimes after longer times, all the case fans would shut down.
Overall, this seriously weirded me out and made zero sense. Weird sensor readings (37000 RPM on some case fans, or stuck case fan readings) didn't help the situation either. ASUS support suggested a potential power issue, and asked me to test a more minimal setup (fewer fans, only one RAM module), but that didn't help either. I then also tried fiddling with fan tuning in ASUS BIOS. First I modified the curves to something else, then I set the fans to full power. Neither helped. I then googled again (last weekend or so) like I have before, but this time I found this reddit post: https://www.reddit.com/r/Amd/comments/8iykdf/the_asus_prime_x470_pro_has_been_nothing_more/
A fellow user with the same problems I had! They claim the problem is ASUS' implementation of PBO doing something it shouldn't or some such. I hadn't even realized it's turned on, so I looked for the setting in the BIOS and set it to "Disabled" from "Auto". But again, it didn't help. I then found the post in the same reddit thread I didn't want to find: https://www.reddit.com/r/Amd/comments/8iykdf/the_asus_prime_x470_pro_has_been_nothing_more/dyxb31b/
Somebody claiming to have had the same problem, and it stopped once they uninstalled HWiNFO. And that's why I'm here. After disabling PBO didn't help, the first thing I did was disable monitoring for any sensor in HWiNFO I didn't need. This left me with the sensors for CPU usage and temperature, GPU usage and temperature and fan speed sensors. But again, same problem. I then tried once more with the fan speed sensors disabled as well. But again, after 8 hours, my fans turned off... so today, for the first time, I didn't have HWiNFO running at all. So far, my PC has been running for about 13 hours with no issues. And so, it really does seem like HWiNFO is the culprit. But why? I'd really like to have it running again, for monitoring temperatures and such...
Tomorrow's a holiday here in Germany, so I'll have enough free time to run the PC long enough for the problem to occur again. I will generate a report and debug file for this report tomorrow. Until then, maybe somebody has an idea what may be causing this.
