I did a BIOS upgrade to 1303, things remained unchanged.
I have some more information. I just changed to this Mainboard after running this for years on an (Asus as well) 2600K Mainboard, which i never faced any issue. Now I have EC=0 and LPC=0 in the config file. I can start HWiNFO normally now, but as soon as I go to Sensors in the UI (Sub Window never opens), the entire system becomes unresponsive (as mentioned even Pings get sluggish, RDP does not disconnect but no more reaction to clicks, while still alive, a script in PowerShell still outputs and the task manger still updates every now and then, login at the console is no longer possible, it doesn't react to the Keyboard or mouse, but time on the login screen does update). If i try hard enough to recover from this by sending CTRL+ALT+DEL or CTRL+ALT+END in RDP, the system will eventually Bluescreen.
I have a suspicion, this Mainboard has an OLED display, which (without any additional software) displays the entire BIOS Stage and thereafter the CPU Temp while running in the operating system. I guess the BIOS does that on the lower level since there is no Software Involved and accesses the Sensors directly. I guess this might be the conflict.
While the display is actually useful when working on the machine, it is pretty useless to me when it runs (it is a mostly headless system anyway), i'll try to see if this somehow can be disabled and if so would HWiNFO then run and be able to access the sensors.
Secondly if the former is the case ,it would leads to the conclusion that there must be a compatible access way as the ASUS Software if installed (god forbid!!) must be able to access those sensors as well be it direct or indirectly (maybe need to IDA if that's the case). Haha, I am a firmware / Software guy so forgive me my need to look for logical explanations
Great Software BTW !
If I can be of any help debugging this (if you are interested) i am more than willing to do so.
