B650 Tomahawk - weird temp readings + high polling time from mainboard sensors?
notwalkin
New to AM5,
Running PBO -20CO
DDR5 6000 32gb (2x16) EXPO on
msi b650 tomahawk, on latest bios.
Two issues.
One, i keep getting lag/stutters when expanding headers to show extra information.
I've noticed hwinfo doesn't update very fast, even when updating the settings to be at 20ms instead of the default 2000ms.
Something is causing the values / sensors to update slowly/stuttery.
I enabled Profiling column and had the mainboard show 800 in the profiling column:
Second issue is incorrect readings for a column that randomly appears regarding ram, showing PCIM values as all set to "yes" even though one is undervolt and one is overvolting, also the temps are in the 3000s.
Is this known for the b650 and hwinfo or is there something going on here.
Are you running some other monitoring or tweaking tool along with HWiNFO? It could be due to a collision between them.
I have Icue open for my fans, on my past system icue ran fine with hwinfo, although i did get the odd warning upon launching.
The only other program i use is Rivatuner for game stats but this hasn't been open today whilst i still had the issue.
I suppose it could be Icue, will try without it open.
some notes:
- I tested the pc without EXPO/PBO and it seemed to be fine from first glance.
- Tested with EXPO on, still seemed fine
- Tested with PBO -20CO and it seemed fine too.
2-3 minutes with hwinfo open and it started coming to a crawl again, Also the 3000c ram temp happened with pbo/expo off.
This was all with icue open though.
