I ran scan of my comp & have a basic question. Is the Ram speed listed the max or what is current at the time of the scan? I'm thinking max. Here is the Ram info,
Row: 1 - 4096 MB PC3-12800 DDR3 SDRAM Kingston HP655410-150-HYCG
[General Module Information]
Module Number: 1
Module Size: 4096 MBytes
Memory Type: DDR3 SDRAM
Module Type: Unbuffered DIMM (UDIMM)
Memory Speed: 800.0 MHz (DDR3-1600 / PC3-12800)
Module Manufacturer: Kingston
Module Part Number: HP655410-150-HYCG
Module Revision: 0
Module Serial Number: 647832761
Module Manufacturing Date: Year: 2012, Week: 42
Module Manufacturing Location: 4
SDRAM Manufacturer: SK Hynix
Error Check/Correction: None
[Module characteristics]
Row Address Bits: 15
Column Address Bits: 10
Number Of Banks: 8
Module Density: 2048 Mb
Number Of Ranks: 2
Device Width: 8 bits
Bus Width: 64 bits
Module Nominal Voltage (VDD): 1.5 V
[Module timing]
Minimum SDRAM Cycle Time (tCKmin): 1.250 ns
CAS# Latencies Supported: 6, 7, 8, 9, 10, 11
Minimum CAS# Latency Time (tAAmin): 13.125 ns
Minimum RAS# to CAS# Delay (tRCDmin): 13.125 ns
Minimum Row Precharge Time (tRPmin): 13.125 ns
Minimum Active to Precharge Time (tRASmin): 35.000 ns
Supported Module Timing at 800.0 MHz: 11-11-11-28
Supported Module Timing at 733.3 MHz: 10-10-10-26
Supported Module Timing at 666.7 MHz: 9-9-9-24
Supported Module Timing at 600.0 MHz: 8-8-8-21
Supported Module Timing at 533.3 MHz: 7-7-7-19
Supported Module Timing at 466.7 MHz: 7-7-7-17
Supported Module Timing at 400.0 MHz: 6-6-6-14
Minimum Write Recovery Time (tWRmin): 15.000 ns
Minimum Row Active to Row Active Delay (tRRDmin): 6.000 ns
Minimum Active to Active/Refresh Time (tRCmin): 48.125 ns
Minimum Refresh Recovery Time Delay (tRFCmin): 160.000 ns
Minimum Internal Write to Read Command Delay (tWTRmin): 7.500 ns
Minimum Internal Read to Precharge Command Delay (tRTPmin): 7.500 ns
Minimum Four Activate Window Delay Time (tFAWmin): 30.000 ns
[Features]
Partial Array Self Refresh (PASR): Not Supported
On-die Thermal Sensor (ODTS) Readout: Not Supported
Auto Self Refresh (ASR): Supported
Extended Temperature 1X Refresh Rate: Not Supported
Extended Temperature Range: Supported
Module Temperature Sensor: Not Supported
Pseudo Target Row Refresh (pTRR): Not Supported
Module Nominal Height: 29 - 30 mm
Module Maximum Thickness (Front): 1 - 2 mm
Module Maximum Thickness (Back): 1 - 2 mm
Thanks,
Trent
Module Number: 1
Module Revision: 0
Number Of Banks: 8
Number Of Ranks: 2
Bus Width: 64 bits
[Module timing]
[Features]
Thanks,
Trent
