Beta 5515 crash
The latest beta (5515) crashes after 2-3 seconds of appearing in the taskbar (or if I delete my INI, after displaying the intro dialog) on my Samsung Galaxy Book 4 Edge (84-100 SOC).
Here is the debug file. I had to edit the INI file directly as I obviously couldn't get to the settings page - I don't know for sure therefore if the file was fully written correctly, as I wasn't able to tick the "Debug Write Direct" option.
Just found something interesting also - I had moved my install folder (obtained via the "portable" zip btw) to "Program Files" - I can't remember why, other than HWInfo itself saying I should to enable some kind of feature (?). This made it trickier to edit the INI file manually. So initially I tried moving the install to a non-admin location, but then, sod's law, it didn't crash. But I was then able to copy the edited INI file back to original location, and the crash still happened, hence the file above.
Thanks, will do - I’m away until tomorrow evening now though so won’t be able to reply until then. I do have PresentMon on though so am hopeful that might be it.
Turning off PresentMon support didn't help unfortunately - I was actually lucky to be able to turn it off, the app lasted long enough for me to get into the menus to change it. I actually think the crash may not have happened in that run. But I quit and restarted, and it died after a couple of seconds as usual. In an effort to see how consistent it is, I ran five more times - it crashed each time. One of these times I tried to get into the menus again, and I got only as far as the initial dialog before the app crashed. Strange one. At least I can run outside of Program Files without it crashing though, so that's fine for some kind of monitoring (I use HWInfo mainly for the OSD though - I want to stay as Arm native as possible so am avoiding things like x64 RTSS).
EDIT - forget that last part, it now crashes when run outside of Program Files also, so must have been a one-off when it worked before.
Do you use the OSD in overlay or independent window mode?
Does it also crash if you disable the OSD?
I think that might be it - I was able to disable the OSD (can it be done via an INI file setting or similar as well btw?), and it reliably didn't crash. I enabled it again, and it reliably crashed.
