Can I run Fan Control at each startup?
thewizardoz
Is there any way that I can automatically run/load Fan Control at each Windows startup please?
I have an Alienware M17xR3 that has lousy fan control. The laptop's fan(s) only speed up at boot up and shut down but not when the CPU temp gets high.
Thanks. :shy:
Yes, put the following line at the end of the HWiNFO64.INI file:
OpenFanCtrlMin=1
You must also make sure that sensors are automatically started in HWiNFO.
thewizardoz
OpenFanCtrlMin=1
OK, thanks Martin. I assume that means that I'll have to make sure that HWiNFO64.exe is loaded at Windows startup first?
