Firego
I have recently downloaded HWiNFO64 to monitor my graphic card under Rainmeter.
The problem is that it worked when I installed it but never worked again after rebooting. I was not able to re-open it, so I decided to completely remove it to retry later. I uninstalled it successfully but I can't delete the remaining exe files. The problem is that apparently it is used by another program. So I checked the process list and indeed it is still running even if it is uninstall. I try to end the task in my task manager and nothing happend. I decided to run the cmd in admin. HWiNFO64.exe appear in the list (tasklist) and when I want to stop it via "taskkill /f HWiNFO64.exe", it tells me "process with PID 1324 can't be stopped. Reason : There are no instance of this task".
So I can't stop the process, I can't delete the files remaining, and I can't manage to run the HWiNFO64 even after re-installing.
I really don't want to format my computer so is there any solutions to either delete it completely or make it work ?
Thank you!
Thank you!
