Guys, I recently set up my computer but it started to restart by itself and in hwinfo it is showing tlb error, does anyone know what it could be?
currently stopped restarting but still showing tlb errors
Code:
Date,Time,"Virtual Memory Committed [MB]","Virtual Memory Available [MB]","Virtual Memory Load [%]","Physical Memory Used [MB]","Physical Memory Available [MB]","Physical Memory Load [%]","Page File Usage [%]","Core VIDs (avg) [V]","Core 0 VID [V]","Core 1 VID [V]","Core 2 VID [V]","Core 3 VID [V]","Core 4 VID [V]","Core 5 VID [V]","Core 6 VID [V]","Core 7 VID [V]","Core Clocks (avg) [MHz]","Core 0 Clock (perf #2/6) [MHz]","Core 1 Clock (perf #1/2) [MHz]","Core 2 Clock (perf #1/4) [MHz]","Core 3 Clock (perf #3/8) [MHz]","Core 4 Clock (perf #5/3) [MHz]","Core 5 Clock (perf #4/1) [MHz]","Core 6 Clock (perf #7/7) [MHz]","Core 7 Clock (perf #6/5) [MHz]","Bus Clock [MHz]","Core Effective Clocks (avg) [MHz]","Core 0 T0 Effective Clock [MHz]","Core 0 T1 Effective Clock [MHz]","Core 1 T0 Effective Clock [MHz]","Core 1 T1 Effective Clock [MHz]","Core 2 T0 Effective Clock [MHz]","Core 2 T1 Effective Clock [MHz]","Core 3 T0 Effective Clock [MHz]","Core 3 T1 Effective Clock [MHz]","Core 4 T0 Effective Clock [MHz]","Core 4 T1 Effective Clock [MHz]","Core 5 T0 Effective Clock [MHz]","Core 5 T1 Effective Clock [MHz]","Core 6 T0 Effective Clock [MHz]","Core 6 T1 Effective Clock [MHz]","Core 7 T0 Effective Clock [MHz]","Core 7 T1 Effective Clock [MHz]","Average Effective Clock [MHz]","Core Usage (avg) [%]","Core 0 T0 Usage [%]","Core 0 T1 Usage [%]","Core 1 T0 Usage [%]","Core 1 T1 Usage [%]","Core 2 T0 Usage [%]","Core 2 T1 Usage [%]","Core 3 T0 Usage [%]","Core 3 T1 Usage [%]","Core 4 T0 Usage [%]","Core 4 T1 Usage [%]","Core 5 T0 Usage [%]","Core 5 T1 Usage [%]","Core 6 T0 Usage [%]","Core 6 T1 Usage [%]","Core 7 T0 Usage [%]","Core 7 T1 Usage [%]","Max CPU/Thread Usage [%]","Total CPU Usage [%]","Core Utility (avg) [%]","Core 0 T0 Utility [%]","Core 0 T1 Utility [%]","Core 1 T0 Utility [%]","Core 1 T1 Utility [%]","Core 2 T0 Utility [%]","Core 2 T1 Utility [%]","Core 3 T0 Utility [%]","Core 3 T1 Utility [%]","Core 4 T0 Utility [%]","Core 4 T1 Utility [%]","Core 5 T0 Utility [%]","Core 5 T1 Utility [%]","Core 6 T0 Utility [%]","Core 6 T1 Utility [%]","Core 7 T0 Utility [%]","Core 7 T1 Utility [%]","Total CPU Utility [%]","Core Ratios (avg) [x]","Core 0 Ratio [x]","Core 1 Ratio [x]","Core 2 Ratio [x]","Core 3 Ratio [x]","Core 4 Ratio [x]","Core 5 Ratio [x]","Core 6 Ratio [x]","Core 7 Ratio [x]","Package C6 Residency [%]","Core C0 Residency (avg) [%]","Core 0 C0 Residency [%]","Core 1 C0 Residency [%]","Core 2 C0 Residency [%]","Core 3 C0 Residency [%]","Core 4 C0 Residency [%]","Core 5 C0 Residency [%]","Core 6 C0 Residency [%]","Core 7 C0 Residency [%]","Core C1 Residency (avg) [%]","Core 0 C1 Residency [%]","Core 1 C1 Residency [%]","Core 2 C1 Residency [%]","Core 3 C1 Residency [%]","Core 4 C1 Residency [%]","Core 5 C1 Residency [%]","Core 6 C1 Residency [%]","Core 7 C1 Residency [%]","Core C6 Residency (avg) [%]","Core 0 C6 Residency [%]","Core 1 C6 Residency [%]","Core 2 C6 Residency [%]","Core 3 C6 Residency [%]","Core 4 C6 Residency [%]","Core 5 C6 Residency [%]","Core 6 C6 Residency [%]","Core 7 C6 Residency [%]","Memory Clock [MHz]","Memory Clock Ratio [x]","Tcas [T]","Trcd [T]","Trp [T]","Tras [T]","Trc [T]","Trfc [T]","Command Rate [T]","CPU (Tctl/Tdie) [°C]","CPU Die (average) [°C]","CPU CCD1 (Tdie) [°C]","Core Temperatures (avg) [°C]","Core0 (CCD1) [°C]","Core1 (CCD1) [°C]","Core2 (CCD1) [°C]","Core3 (CCD1) [°C]","Core4 (CCD1) [°C]","Core5 (CCD1) [°C]","Core6 (CCD1) [°C]","Core7 (CCD1) [°C]","L3 Temperatures (avg) [°C]","L3 Cache (CCD1:CCX1) [°C]","L3 Cache (CCD1:CCX2) [°C]","CPU IOD Hotspot [°C]","CPU IOD Average [°C]","CPU Core Voltage (SVI2 TFN) [V]","SoC Voltage (SVI2 TFN) [V]","CPU Core VID (Effective) [V]","CPU Core Current (SVI2 TFN) [A]","SoC Current (SVI2 TFN) [A]","CPU TDC [A]","CPU EDC [A]","CPU Package Power [W]","Core Powers (avg) [W]","Core 0 Power [W]","Core 1 Power [W]","Core 2 Power [W]","Core 3 Power [W]","Core 4 Power [W]","Core 5 Power [W]","Core 6 Power [W]","Core 7 Power [W]","CPU Core Power (SVI2 TFN) [W]","CPU SoC Power (SVI2 TFN) [W]","Core+SoC Power (SVI2 TFN) [W]","CPU PPT [W]","Infinity Fabric Clock (FCLK) [MHz]","Memory Controller Clock (UCLK) [MHz]","L3 Clocks (avg) [MHz]","L3 Cache (CCD1:CCX1) [MHz]","L3 Cache (CCD1:CCX2) [MHz]","Frequency Limit - Global [MHz]","CPU PPT Limit [%]","CPU TDC Limit [%]","CPU EDC Limit [%]","Thermal Limit [%]","Power Reporting Deviation (Accuracy) [%]","Thermal Throttling (HTC) [Yes/No]","Thermal Throttling (PROCHOT CPU) [Yes/No]","Thermal Throttling (PROCHOT EXT) [Yes/No]","DRAM Read Bandwidth [Gbps]","DRAM Write Bandwidth [Gbps]","Average Active Core Count []","System1 [°C]","VSOC MOS [°C]","CPU [°C]","Temperature 4 [°C]","VRM MOS [°C]","PCH [°C]","Vcore [V]","+3.3V [V]","+12V [V]","+5V [V]","CPU VCORE SoC [V]","CPU VDDP [V]","DRAM [V]","3VSB [V]","VBAT [V]","AVCC3 [V]","CPU [RPM]","Chassis Intrusion [Yes/No]","VR Loop1 [°C]","VR Loop2 [°C]","VR VOUT [V]","VR VIN [V]","Current (IOUT) [A]","Current (IIN) [A]","Power (POUT) [W]","Power (Input) [W]","VR Loop1 [°C]","VR Loop2 [°C]","VR VOUT [V]","VR VIN [V]","Current (IOUT) [A]","Current (IIN) [A]","Power (POUT) [W]","Power (Input) [W]","Drive Temperature [°C]","Drive Remaining Life [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total NAND Writes [GB]","Total Host Reads [GB]","Drive Temperature [°C]","Drive Remaining Life [%]","Drive Available Spare [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Drive Temperature [°C]","Drive Remaining Life [%]","Drive Available Spare [%]","Drive Failure [Yes/No]","Drive Warning [Yes/No]","Total Host Writes [GB]","Total Host Reads [GB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","Read Activity [%]","Write Activity [%]","Total Activity [%]","Read Rate [MB/s]","Write Rate [MB/s]","Read Total [MB]","Write Total [MB]","GPU Temperature [°C]","GPU Hot Spot Temperature [°C]","GPU Thermal Limit [°C]","GPU Core Voltage [V]","GPU Rail Voltages (avg) [V]","GPU PCIe +12V Input Voltage [V]","GPU 8-pin #1 Input Voltage [V]","GPU Misc0 Input Voltage [V]","GPU Fan1 [RPM]","GPU Fan2 [RPM]","GPU Power [W]","GPU Rail Powers (avg) [W]","GPU Core (NVVDD) Input Power (sum) [W]","GPU PCIe +12V Input Power [W]","GPU 8-pin #1 Input Power [W]","GPU Misc0 Input Power [W]","GPU Core (NVVDD2) Input Power (sum) [W]","GPU Input PP Source Power (sum) [W]","GPU Core (NVVDD) Output Power [W]","GPU Core (NVVDD) Output Power [W]","GPU Clock [MHz]","GPU Memory Clock [MHz]","GPU Video Clock [MHz]","GPU Effective Clock [MHz]","GPU Core Load [%]","GPU Memory Controller Load [%]","GPU Video Engine Load [%]","GPU Bus Load [%]","GPU Memory Usage [%]","GPU D3D Usages (avg) [%]","GPU D3D Usage [%]","GPU Video Decode 0 Usage [%]","GPU Video Encode 0 Usage [%]","GPU Computing (Compute_0) Usage [%]","GPU Computing (Cuda) Usage [%]","GPU Computing (Compute_1) Usage [%]","GPU VR Usage [%]","GPU Graphics Usage [%]","GPU Fan1 [%]","GPU Fan2 [%]","GPU Performance Limiters (avg) [Yes/No]","Performance Limit - Power [Yes/No]","Performance Limit - Thermal [Yes/No]","Performance Limit - Reliability Voltage [Yes/No]","Performance Limit - Max Operating Voltage [Yes/No]","Performance Limit - Utilization [Yes/No]","Performance Limit - SLI GPUBoost Sync [Yes/No]","Total GPU Power [% of TDP] [%]","Total GPU Power (normalized) [% of TDP] [%]","GPU Memory Available [MB]","GPU Memory Allocated [MB]","GPU D3D Memory Dedicated [MB]","GPU D3D Memory Dynamic [MB]","PCIe Link Speed [GT/s]","Framerate (Presented) [FPS]","Framerate (Displayed) [FPS]","Frame Time [ms]","GPU Busy [ms]","Total DL [MB]","Total UP [MB]","Current DL rate [KB/s]","Current UP rate [KB/s]","Total Errors []","CPU TLB Errors []",
23.3.2024,19:12:48.254,25594,11958,68.1,15748,16940,48.1,3.9,1.430,1.425,1.431,1.431,1.431,1.431,1.431,1.431,1.431,4317.2,4317.2,4317.2,4317.2,4317.2,4317.2,4317.2,4317.2,4317.2,99.8,994.0,2436.2,602.6,1381.0,1316.2,1773.3,1174.2,970.0,699.7,685.7,433.7,972.6,471.8,1285.1,649.1,665.0,388.1,994.0,18.5,30.5,9.4,27.3,25.8,33.6,23.4,14.1,14.8,14.8,10.9,20.3,11.7,25.0,10.9,14.1,8.6,33.6,18.5,25.0,38.7,15.7,37.5,35.7,48.5,31.7,26.0,18.4,18.2,11.3,26.1,12.3,34.5,17.0,17.7,10.1,25.0,43.3,43.3,43.3,43.3,43.3,43.3,43.3,43.3,43.3,0.0,55.0,56.9,64.5,69.4,53.7,45.5,49.5,56.0,44.7,45.0,43.1,35.5,30.6,46.3,54.5,50.5,44.0,55.3,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,1197.8,12.00,16,16,16,39,55,421,2,50.5,47.2,45.3,42.5,42.5,44.2,45.6,41.9,41.0,41.8,41.9,41.0,39.1,39.3,39.0,32.8,31.2,1.431,1.019,1.431,10.148,9.111,10.139,48.919,33.032,2.913,2.823,3.949,4.544,2.550,2.035,2.450,2.912,2.038,14.269,9.252,23.521,32.311,1197.8,1197.8,4271.8,4287.1,4256.6,4319.9,36.7,16.9,54.4,49.7,62.3,No,No,No,0.565,0.063,4.4,28,45,50,21,43,35,1.404,3.384,11.952,5.070,1.020,0.912,1.224,3.312,3.072,3.072,1762,Yes,46.0,38.0,1.395,12.020,6.500,0.980,14.000,11.000,41.0,38.0,1.012,11.950,9.100,0.840,8.000,9.000,28,54.0,No,No,35025,18444,39548,48,100.0,100.0,No,No,3295,3339,29,99.0,100.0,No,No,15683,16088,0.0,0.1,0.1,0.049,0.168,10659,9941,0.0,0.0,0.0,0.000,0.018,15649,1805,0.0,0.0,0.0,0.000,0.006,28,3,42.3,53.0,83.0,0.644,12.017,11.990,12.050,12.011,0,0,18.223,7.206,6.358,3.273,14.146,10.329,5.725,11.701,1.156,4.961,622.0,202.5,555.0,616.8,28.0,20.0,0.0,1.0,34.4,4.6,36.7,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0,0,Yes,No,No,No,No,Yes,No,10.3,10.5,8058,4230,4085,478,5.0,69.8,69.9,14.32,0.73,4554,206,7.758,1.214,2,2,
,,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,System: GIGABYTE B550M AORUS ELITE,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,CPU [#0]: AMD Ryzen 7 3700X: C-State Residency,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,Memory Timings,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,CPU [#0]: AMD Ryzen 7 3700X: Enhanced,GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (ITE IT8689E),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),GIGABYTE B550M AORUS ELITE (Renesas RAA229004),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: KINGSTON SUV400S37120G (50026B776C025E01),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: WALRAM 1TB (SCRW22120103B0506),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),S.M.A.R.T.: NVME SSD 512GB (2021031201527),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: KINGSTON SUV400S37120G (50026B776C025E01),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: WALRAM 1TB (SCRW22120103B0506),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),Drive: NVME SSD 512GB (2021031201527),GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,GPU [#0]: NVIDIA GeForce RTX 3060: Zotac RTX 3060 Twin Edge OC,PresentMon,PresentMon,PresentMon,PresentMon,Rede: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Rede: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Rede: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Rede: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC,Windows Hardware Errors (WHEA),Windows Hardware Errors (WHEA),
