Crash while sensor scanning
fkstgt
While scanning the sensors I get an crash at sensor IMPI#1. I use a Supermicro X8DAH+-F. The bug report file is attached.
Thanks for any help!
There seems to be a problem with the IPMI driver in system. There are 2 options available:
1. Either try to upgrade/change the IPMI driver or
2. Try to disable the IPMI driver. In this case HWiNFO will try to use an alternate method.
Please let me know if that helped.
fkstgt
I have now upgraded the IPMI firmware, but this did not help. I don't think that there is a IPMI driver in the system, because I use Windows 7 x64.
According to the dump you attached earlier, there's indeed an IPMI driver in system and HWiNFO is trying to communicate with it.
