@Martin
Hi again!
I have a humble request - would you mind adding 2 things to the HWINFO:
A. VDDCI aka Memory Controler voltage - "Memory Voltage" setting in WattMan (Radeon Settings).
I've found that no software can do this! And this is important voltage because the GPU VDDC voltage level cannot be lower than this.
So, there are a lot of mistakes people do in this regard and it will be very helpful to have such sensor.
B. When it comes to our talk about the GPU Power Only reading for RX 4xx and the discrepancy between HWINFO and GPUZ, there is something far far more important - and a lot of people are looking for it
It would be really really nice if HWINFO would have possibility to display Power Consumption for:
1) PCIE slot, and 2) PCIE connector(s) on a card...
Ad 1) I've heard that "GPU VRM Power in (PIN)" in HWINFO = PCIE slot power usage, just I don't know if it's true?
Ad 2) I've heard that GPUZ in its "GPU only Power Draw" = PCIE connector power usage - but again, I don't know if it's true too...
This PCIE slot power usage display for the Polaris series is really very important - especially after the infamous initial RX 480 affair
Thanks for Your hard work!
Have a nice weekend
Cheers
P.S. That 'GPU only Power draw' is of no use because the GPU draws current both from the slot and from the connector(s)...
