Hi, im new to these forums but been a long time user of this amazing piece of software, so thank you to the Devs.
With the release of Ryzen 9000 and MSI afterburner not supporting them, app no longer being developed, ive taken to using HWInfo RTSS OSD instead, however to make it look familiar ive renamed some of the sensors so that they are more recognisable / familiar in games to how MSi afterburner used to display them.
the only downside to that of course is they are no longer so easily recognisable in HWInfo monitoring panel, so it it possible to have 2 instances installed on the same PC, maybe 1 portable and one installed ?
Like launch the portable version for OSD and gaming with adjusted sensor names and have the installed version for stock sensor names and monitoring ?
Ive tried this myself and for some reason, they are both showing the same adjusted sensor names, is there a config file somewhere I can adjust to get them to display differently ?
So ive attached a couple of picts so you can see what I mean.
