EPYC Rome ES CPU temperature
chraac
HWinfo sensors: CPU Die (average) is IMHO nonsense. in the IPMI sensor page is nothing hot.
IPMI sensors
Thanks for the important picture, may cpu is B0 stepping and the temp in ipmi is not as high as the die average, from you picture I see your CPU also high in this die average temp, so I think it's probably because of the ES stage CPU.
Chozo4
Ok, but EPYC with windows and running hwinfo is hard to find.
If it helps... I'm running a Production Sample EPYC 7252 on bare metal here under Windows 10 1809. Noticing a similar trend with the CPU Die (Average) temp accordingly which may point to this not being an ES exclusive issue or even specific to 7452/7502 for that matter. There is barely any load on the CPU at the moment.
I would be happy to lend myself to any further testing needed.
Well, then this seems to be an issue of the SMU which calculates such a high average value.
There's a new feature in works now, which is currently just waiting for AMD's approval: per-core temperature monitoring. If this gets approved (which I expect/hope to happen in the next couple of days), it would give you a better insight into individual temperatures to confirm what's correct and what isn't.
